Help! PSM & all wheel drive failure
Hello everyone,
Maybe someone can help find a problem at high speed. I have a 2019 Turbo stage 5 with meth. In a track, in Sport + mode and PSM on, when I let go of the gas pedal at 150-160mph, I get PSM and all wheel drive failure and goes to Normal mode. I fix this with ignition off and on.
Any help with this is appreciated.
Thank you very much,
Hello everyone,
Bumy0Pr (09-08-2024)
It drives perfectly only in Normal mode.
To tell you the truth, I think is the sensor. It probably is a 2 bar map sensor and needs to be a 4 bar map sensor. It’s located before the throttle body so when I close it the pressure increases too much and there is the code.
