.2 paddle extensions
![](https://rennlist.com/forums/images/ranks/veteran_navy.png)
I installed the Carbon Fiber stick on's about a year or two ago. Takes less than a minute to put on. No issues. The only negative is the extended paddles will block a little bit of your view on portions of a couple gauges.
I got the replacement paddles from AutoTecknic. Very high, OE quality. You have to remove the wheel to install, though. I did it when swapping to a 991.2 wheel. Also, they only come in satin black. And, yes, they block some of the side gauges.
https://autotecknic.com/products/aut...caAraAEALw_wcB
Foosh (07-10-2024)
RadarP3C (07-10-2024)
We had an Alfa Romeo with paddles fixed on the steering column, and I found myself really preferring them. Ferrari does it that way too.
So where did you get them? As noted in the post above yours, Suncoast no longer has them. I do agree they would help with reaching the paddles at off-center steering wheel angles.
RSBro (07-12-2024)
I ended up ordering from https://www.dsg-paddles.com/ but was not aware this is a China company. Well see how the quality is
Foosh (07-12-2024)
