Sponsored by: Road Spy
Methanol Injected Cars
Old 04-19-2024 | 12:47 AM
TonyO's Avatar
TonyO
Default Methanol Injected Cars
What oil are you using in your methanol injected car?
Old 04-19-2024 | 07:04 AM
xhrix's Avatar
xhrix
5w-50 motul or mobil 1 but most important is change it frequently. I do around 1,500 miles depending how I drove during that time.
Old 04-19-2024 | 08:03 AM
Pb Pedis's Avatar
Pb Pedis
Motul
Old 04-21-2024 | 12:59 PM
sirius9's Avatar
sirius9
Liqui Moly 10w60
Old 04-21-2024 | 01:43 PM
vtec_'s Avatar
vtec_
does methanol effect oil life?
Old 04-21-2024 | 04:03 PM
xhrix's Avatar
xhrix
All cars, and turbo cars have even more blow by. The fact that there is much more fuel put in methanol will get by and dilute oil for sure. In addition I think it gets worse on liftoff as I dont believe the snow performance injectors control that quickly the flow which puts excess methanol.
I think with these cars at high boost need more frequent oil changes and heavier oils.
i dont have any oil analysis but would be nice if someone has some facts.
cheers
Old 04-21-2024 | 05:48 PM
Angryinch's Avatar
Angryinch
Here you go, Stage4 992 TTS with 100% meth inj. Lamda around 0.83. I think this oil had around 4000-4500km on it.
2.5% fuel in the oil which is starting to drop the viscosity a bit.
(the first sample is break in oil with around 3500km on it)
Nikolov (04-22-2024)
Old 04-21-2024 | 10:21 PM
xhrix's Avatar
xhrix
First, you are the man running a stage 4 with meth on a 992 already. Must be awesome!
2.5% does not seem bad! but I have a 2014 991.1 with 85k miles on it. Probably a bit more blow by!
which tuning software/ecu do you use?
Old 04-22-2024 | 12:55 AM
Angryinch's Avatar
Angryinch
@xhrix M Engineering, custom tuned by Mitch.
Quick Reply: Methanol Injected Cars
