Easy cabin filter replacement - saved $150 at least
Cabin filter housing to the left…you can see dirty white filter below lid
Plastic clips
25,572 or 4 plus years in Atlanta driving conditions..
Easy to check before changing - it curves in…
Under glovebox insulation cover - 3 plastic screws
Interior filter housing cover - 3 clips to undo
Insulation cover under glovebox
Sliding filter out
Dirty enough to change…originals made by Behr…
Easier space wise and with slotted plastic screws to use a quarter…and hopefully you can use your left hand
Flexible at 68…..tip….have new filter with you so you don’t have to get out and reposition yourself…and use a smartphone light))Bought OEM filters on Amazon…..saved at least $ 110 on parts and probably $100 on labor at dealer…
Beezupra (11-13-2022)
abiazis (11-14-2022)
Pardon my dumb question - is there one or two cabin filters? 🤔
abiazis (11-16-2022)
