991.1 Turbo S PSM question
Hello everyone, I recently bought a 2013 991.1 Turbo S but I have a question regarding the PSM.
I know that PSM lets you to be more free for oversteering when you are in Sport Plus mode. But Sport Plus mode is less usable during normal cruising except you are in manual (PDK). I believe you are able to only tune PSM with second generations (991.2). Is there a way I can achieve this with my 991.1?
Summary for what I am trying to achieve:
PSM: Sport Plus (Less support)
PASM: Normal/Sport
Engine/Transmission: Sport
PASM: Normal/Sport
Also curious about this - my '19 TTRS is a bit more individualized in allowing the driver to define suspension, transmission, and engine runtime parameters. Seems odd that a 911TS only 3 years older would not permit this.
Rocky Mountain High
The 991.1 cars will hold the chosen gear until red line in Sport Plus mode, so most people shift manually if they’re using Sport Plus. The front and rear spoilers fully extend in Sport Plus mode also, which isn’t always ideal for the street. As a result, I virtually never drive the car in Sport Plus. I typically drive the car in Sport mode when I’m on the street. The chassis settings are selected independently with PDCC. You can run that in Normal or in Sport mode regardless of the other settings. I typically run mine in Normal mode, but I’ll switch it to Sport on a twisty mountain road.
ndfin (09-25-2023)
