Sponsored by: Road Spy
Navigation & Infotainment Services Help
Old 07-09-2022 | 01:05 AM
6speeddave's Avatar
6speeddave
Originally Posted by onfireTTS
My TTS is a 2019. Bought connect back then. Have not turned anything off that I can find. So far, everything still works on 3G on Connect.
This is great info so thanks again for your input. It may make sense for you to reach out to your dealer or Porsche Connect themselves to find out why your map is still 4 years old and hasn't updated when you've been paying for it. Id suggest doing this before the end of this month since there is the possibility that this entire thing becomes extinct by then. This is, of course, if you care or not about your maps, etc!
onfireTTS (07-09-2022)
Old 09-27-2022 | 08:37 AM
hiflyin20's Avatar
hiflyin20
5th Gear
How are you guys manually changing the charging amperage? When I try through the settings display on the charger it’s just blank. This is totally unacceptable from Porsche.
Old 09-27-2022 | 11:44 AM
IainC's Avatar
IainC
Not sure if you're wanting to update your maps manually, but if so, this guide may help: https://rennlist.com/forums/991-turb...-in-991-a.html
Quick Reply: Navigation & Infotainment Services Help
