Center Lock Wheel Change - 2014 Porsche 911 Turbo S - HRE Wheel Upgrade
Yes, even when loosening, the wheel should be off the ground. The reason to back off 1/6th of a turn is to evenly spread the Optimoly across the face of the center lock to help ensure the torque is focused solely in attaching the wheel and not somehow due to friction on the face. Not sure 1/6th vs 1/4th really matters that much. But according to my Porsche tech buddies having the wheel off the ground is important so as not to introduce stress to the assembly.
Good catch on the inner splines being extended so as to lock the nut. Some forget that part. Also some company has made a tool, for $50, to giggle that part to help it come out and lock. As you have found anything will work including a rachet extension.
verrucktaxe (09-22-2021)
Welcome. I have a lift in my garage and am on my second TTS with center lock wheels. Many on the forums will bad mouth them, but I actually like them. I've had them on and off so many times it's just second nature now. The biggest threat is getting Optimoly on something and then spreading it all over the place!
The following 3 users liked this post by WaltB:
you wanna see the forum members bad mouth something, read the thread where i stripped all the porsche crests off mine and replaced them with chrome mashined axes haha.
Chrome machined axes. Well this is your thread and that is your car so you are welcome to do what you want with both, however, just for the record, if I was to respond to your other thread it would be in a hugely negative way.
hahaha as expected, but yeah, my car, my look for sure.
Does anyone know if this statement in regards to the center locking wheel grease "Wheel bolts must be greased and tightened to a higher tightening torque according to Porsche" (taken from suncoast website) was updated on the Porsches Good to know..
what are the correct Torque specs for a 2018 GTS 911...it says 600Nm \ 443 ftlb..but is that the higher torque they are talking about ?
600Nm/440ftlb is the correct torque. It actually was lower when they came out ,2010, but there were some issues and Porsche raised the torque to the current specs. Also, after so many track hours many of the components need to be replaced as per a maintenance schedule.
The following 2 users liked this post by WaltB:
ihbond (09-22-2021),
verrucktaxe (09-23-2021)
final touch are blacked out center caps in this vid.
