pin connectors
6th Gear
pin connectors
A few pins broke and now I need to replace a few female pins from my rear body connector and parking control module, which are both located under the drivers side seat.
I am having trouble finding a part number for the pin connectors or the actual connectors. Does anyone know what is the best way to proceed? Any help will be greatly appreciated.
Should be a PN on the connector. I broke the front bumper main harness connector. Porsche would only sell they entire harness, I ended finding the connector at the local VW dealer. You'll also need to figure out what extraction tool to use to remove the pins.
6th Gear
I appreciate the reply, but there is no part number on the connector and my mechanic told me his is sure it is an Audi connector. The issue I have is the pin broke on the actual ecu and before I install the new ecu, I need to fix the female pin connectors that have the broken pins inside.
I tried extracting the broken pin, but there was to much corrosion and the wire needs to be cut and a new female pin connector needs to be attached. I am looking for the female pin connectors, not the actual complete connector. I might need to stop by an audi dealer, since the porsche dealer was not able to locate the part.
Could very well be an Audi part. Like I was saying I bought the replacement connector for my 911 at the VW dealer. Porsche parts really don't deal in selling connectors/pins. I'm not familiar with the connector you're talking about, maybe post a pic of it? The connector I replaced, the pins were released from the face. It required a fork type extraction tool.
6th Gear
I will try to the local Audi dealer and see if they might have something that works. The Porsche dealer told me they can only supply the complete body harness.
