Finally found the almost perfect frunk organizer
#33
You can fit a pony keg in there.... Use cases to stop it from rolling.... (good consumer advice) If you plan to keep your spine you will have to set one foot in the frunk to pick this thing out assuming its full.
#35
Steve 96C4S (04-11-2021)
#36
Don't forget the aerokit, that also looks fantastic. I have never even seen a TTS with one in the wild. Rare.
#38
A better frunk - Fortem Car Trunk Organizer, Foldable Cover, Non-Slip Waterproof Bottom, Straps, Cargo Storage (2 Compartments, Black)
organizer vs the Porsche plastic tub which I was rather happy to swap out. The velcro underneath this organizer also help keeps it in place.
#39
I had been searching through trying to find the perfect organizer for the frunk, but wasn't having much luck. I took some measurements and went to Amazon and came across this very cheap organizer by Fortem, then got it on a lighting deal for $25. This thing is exactly what I wanted so I thought I'd share.
FORTEM Car Trunk Organizer, Foldable Cover, Waterproof Non Slip Bottom, Strap... via @amazon
FORTEM Car Trunk Organizer, Foldable Cover, Waterproof Non Slip Bottom, Straps, Cargo Storage (2 Compartments, Black)
Collapsible bucket, first aid kit, jump starter, and mini air compressor hidden in the bucket there.
With the lid on the FORTEM.
Anyway, figured someone here might find this useful.
MAD3 (01-27-2024)
#44
As an alternative, not quite as fancy as the above but having the advantages of folding away when unneeded and only about $7 at costco, is the 12 gallon 'instacrate'. Excellent frunk fit in both my 991 Turbo and the 996 Turbo. And yes, my torque multiplier for centerlocks sits in my toolbag which sits in my instacrate .
Beezupra (02-03-2024)
