The other day...
The other day...
I was sitting in the car, with the nose pointing uphill, running waiting for someone to get off the train.
A couple of things happened - the first was the oil to full light came on again (this is after having a half liter removed, and no issues since, temp. was about 90 deg C), and I was wondering if this warning (yellow) was related to how the nose was orientated, or if anyone else has seen this themselves.
The second thing was a great deal of 'steam/condensation' ((visible) coming up from the right front. I got out and had a look, but it didn't smell of coolant and nothing is leaking. The air conditioning was on, and it was a rather damp evening at about 7 deg C - is it possible that the heat transfer through the condenser was being cooked by a rad? I haven't taken the fron of the car apart, so I don't really know how it all goes together, but would welcome some ideas.
Cheers,
Cheers,
Ok - there was quite a bit of steam at one point; people were staring...
Basic Sponsor
The cooling system on these cars is a real...situation haha. I am sure you will be fine. You should see what they do after major services or engine removal! Oil makes sense at an angle.
Proud TOP Porsche Distributor For:
Kline-Innovation - ams Performance - TiALSPORT/XONA - #1 COBB PRO TUNER - CSF - IPD Plenums - DO88 - dodsonmotorsport
310-600-1850 - sam@bydesignauto.com
So, perhaps you would be so kind as to elaborate on 'situation'...
You would figure that by now, they'd have figured it out.
MotoJB (11-25-2019)
The silly little yellow light is still on, cold/hot oil doesn't matter.
How does one go about resetting it?
