Aftermarket I/C - need to peek at them
Hey all,
So as some know, I bought my car as a 2015 CPO... and the more I look at my car the more I am seeing aftermarket parts on here.
It started with what I thought was a completely stock car, only to have my buddy point out I had aftermarket suspension.... As my mechanic did some modifications, I started to notice other "upgraded" parts.
I had my exhaust put on, and it appeared that the car might be sporting some aftermarket intercoolers. BUT we couldnt really verify this completely.
So I am wondering if there is a way to check this out when the car goes in next week for a little work that will involve removing the engine lids, fans and possibly the tail lights. Basically exposing the engine
I know someone told me that if the end tanks are black plastic, then they are stock, but I have tried to look (and maybe I am not looking in the right location) but I just really cant see the end tanks. Of course, this is from under the car (when the exhaust was being installed) and there was nothing removed....
Any help would be great. Trying to get my car all buttoned up and of course, that has me on a hard path to get everything done that the car needs and I would hate to buy something only to find out I already have it
Hey all,
If you just want to check intercoolers, removing the right most panel in the wheel well should give you enough access to see them without removing anything else but the rear wheel, you can probably even access it with the wheel on.
