What happens if I disconnect my battery?
Received 1,691 Likes
"It" - the car - cannot tell the difference. That's why the PIWIS laptop is required: to tell the car that you have replaced the battery with a new and/or different-Amp-Hour one.
All this, under the assumption that all of this effort is to ensure that the stop/start system works as-designed.
Personally, stop/start OFF is default for our entire fleet. So, I don't GAF about stop/start.
Only those folks that make regular use of stop/stop *may* need to worry about keeping the battery statistics current in the ECUs.
Again, all of this is *speculation.* If PAG would open-source all of the code we could paw through it and determine exactly what's what.
Tom's link confirms my speculation.
Although, I think the warnings about damaging "your car’s fragile electrical system" is ... rather ... over-stated.
Perhaps alternators and AGM batteries are a different beast than in the 'old' days of the infant '00s. But, alternators have been 'over-charging' lead-acid batteries for almost a century and alternator and electrical system lifetime hasn't been an issue. Thus, I will remain skeptical of 'damaging' my Porsches' fragile electrical systems by not PIWISing the battery.
