TTS Tire Size on Rear
#32
The result. Fronts: 9 x 20, Offsets: 52mm, 245/35; Rears: 12 x 20, Offsets: 47mm, 305/30. Forgeline GA1R-CL, Graphite. Michelin Pilot 4S tires. No rubbing, or throwing of codes. The rolling ratios are close to OEM (< 1% from stock) The rear sidewalls are approximately 3/8” out of the wells, when looking straight down on them. Wheels track a bit wider. ~1” in back, ~1/2” up front.
#34
Yeah, I just wish Super Sport Michelins came in that size...those being my preference.
Do you have the specs of the front wheels you paired with the rears? Also, can you take a photo looking down on the fender and wheel? I’d like to go with this spec tire, given that 305s are at their maximum stretch across the 12” wheels. But I don’t want the wheel to be too far out of the well.
