991.2 ECU Removal
991.2 ECU Removal
I have looked around but don't see any tutorials or videos showing how to remove the ECU out of a 991.2 Turbo S.
Not sure if its different that previous years. Anyone have any links or info?
IF , and inly if, because i'm not sure 100%, the ECU is in the engine bay, on the right side ( as you look at the car), under the rear window.
So, you will need to remove some parts to get there, and i will gladly explain if you need it.
