Great 991 phone holder option
I searched this some time ago and went with:
T-Design9.com. The one I went with is under Magnetic mount, but I only ordered the "custom" bracket from T-Design (email Vlad). I wanted to be able to adjust the angle of my phone to be towards the driver along right hand side of the PCM display. Then I picked up the adjustable mount to attach to T-desing bracket from amazon.
adjustable magnetic mount:
Magnetic Phone Holder - TACKFORM [ Tack Mount ] V.2.0 w/N52 Magnets [ for Car, Kitchen, Bedside, Bathroom ] Stick On Dash Mount with Authentic 3M Sticky Adhesive, for Phones, Tablets, and GPS Units (less than $9)
No problems and works great. No adhesive/damage to car what so ever and easily removable.
"custom" bracket from T-Design slides into dash grooves and uses tension to hold in place.
Hello Oz,
Thank you for the pics, they are an inspiration.
I hope I am not too late to ask about the Scosche MagicMount you installed.
I have a 2015 C4S and your installation is exactly what I wanted to do but could not find the phone base holder that would fit inside the small coin holder or container on the 911 (like you, I do not have the cigarette lighter option).
Question: there are small ridges inside the container. Please confirm the adhesive was thick enough to properly adhere to the inside our cup holder?
Hello Oz,
How is the magnet strength with the Rennline; I have a iPhone 8+ which has wireless charging which means the metal plate needs to be attached on the bottom third of the phone so as not to interfere with the wireless charging feature.
Not sure I understand what you mean. However, the installation of the Rennline phone mount as provided for by 928 GT R will impede the deployment of the cup holder. As such, I think I will order the Rennline pedestal or console mount to be installed on the right hand side or passenger side of the vehicle.
I would call the company on that one. I use an Apple 10 and the magnet is in the middle. The phone you have is larger and with the magnet on the bottom it will create some serious leverage.
I have an iPhone X, and I found that by putting the circular metal plate that comes with the Magnetic mount at the very top of the phone, the phone stays in place perfectly and I still have magnetic charging.
After putting the mount in the 911 my wife asked why I hadn’t done the same thing in her QX80. I bought the Pro Clip for her car and I can tell you that the magnet in the Pro Clip is MUCH stronger than the Rennline. However, the way I have mine set up the bottom of the phone rests on the console and it doesn’t move at all.
Do you mean the "magnet in the Scocshe MagicMount" vs Pro Clip is MUCH stronger?
If I install a Rennline it will be on the console passenger side. Numerous YouTube videos mention the interference with the cup holder. I also do not want to block the PCM display.
