Sponsored by: Road Spy
Best tires for my Porsche turbo??
Old 08-03-2017, 02:49 PM
ace37
ace37's Avatar
Originally Posted by Deckard
Thanks for the info--what size tires are appropriate if we want to run with a wider 255 for the fronts?
It's less about exact size and more about keeping be outer diameter the same. If you check up on one of the tire size calculators you can get a size change compared to stock (and front to rear change if you change both sizes). The biggest concern with all wheel drive cars is typically making sure the front to rear ratio isn't way out of line so torque doesn't get pushed to one axle all the time due to perceived slip or what not. I haven't heard a well educated technical discussion of the topic but would be interested to. (Since ours are electronically controlled perhaps Porsche could account for this?)
For reference though the Porsche recommended winter rears are 295s. I haven't checked the size or details since I'm on a mobile and it's a pain, but my guess is since that's ok you're probably ok with your setup as well.
Old 08-08-2017, 02:45 AM
Karl911
Karl911's Avatar
The best choice by far MSC2s at 34 psi cold.
Also I run 265/35, 325/30
Old 08-08-2017, 10:06 AM
thebigboum
thebigboum's Avatar
Michelin Super Sport are great very quiet and amazing grip
Old 08-08-2017, 11:09 AM
BOOSTED TTS
BOOSTED TTS's Avatar
On stock rims?
Manuel
Old 08-09-2017, 10:12 PM
Need4S
Need4S's Avatar
Originally Posted by KBS911
Michelin Super Sports for all round driving. Cup 2's if you track more than 3-4 times a year.
+1. But I would update this by suggesting Michelin Pilot 4S instead of Super Sports.
Quick Reply: Best tires for my Porsche turbo??
