991 GT3 Iron Rotor Replacement
Former Vendor
RB (RacingBrake) is pleased to announce the release of light weight track duty high performance two piece rotors.
Front: (380x34mm)
Weight: 25.16 lbs (vs. 24 lbs of Center Lock and 27.6 lbs of 5-Lug hub)
Rear: (380x30mm)
Weight: 20.38 lbs (vs. 24 lbs of both Center Lock and 5-Lug hub)
Pictures shown are for Center Lock, 5-lug are also available.
Front: http://www.racingbrake.com/Two-piece...-GT-p/2421.htm
Rear: http://www.racingbrake.com/Two-piece...-GT-p/2422.htm
Complete car kit including RB calipers w/top pad load feature:
http://www.racingbrake.com/RB-Calipe...por-irp-02.htm
Please click below to view our comprehensive offer w/different options and possibility for your Porsche's.
http://www.racingbrake.com/category-s/7139.htm
Options for upgrading to pccb size brake kits (410x34 front; 390x30 rear) with stock red calipers will be announced shortly.
Rotors are ready to ship with guarantee fitment and performance.
Thank you.
Front: (380x34mm)
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/800x533/2421_e43125f3a512484460a1aeb1d46b5180cafb40e8.jpg)
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/800x533/2421_weight_2e252a769db76d5dc6bf3f64f897a8f9c932f447.jpg)
Rear: (380x30mm)
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/800x533/2422_2be7ea49c5c5ef6fec2d2235ca1c23477d0f1c06.jpg)
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/800x533/2422_weight_f599804ed15457d642c8f5d334a172164cf6b435.jpg)
Thank you.
Received 1,224 Likes
I honestly considered these options when replacing stock rotors, but could not see a valid reason to go with this over OEM because OEM is almost 1/3 cheaper and does the job very well (no overheating, no cracking, not heavier). So what's the reason for using these over OEM?
What is the benefit of drilling slots? From what i understand you get slotted rotors so they don't crack as fast as the cross-drilled rotors do while still providing great stopping power.
Former Vendor
OE Front: 380x34mm
OE Rear; 380x30mm
They are dual (aluminum hat+iron ring) cast and not a two piece rotors, the rings are not replaceable.
Drilled holes always clog up with brake debris, and "crack" from heat stress under even street driving (picture shown is a GT-R rotor):
Comparison / Pro & Con on different disc finishes (Surface slot; Drilled holes & Open slots):
http://www.racingbrake.com/v/main/two_piece_compare.asp
RB patented Center Mount two piece rotor advantage over traditional Surface Mount two piece rotors
http://www.racingbrake.com/v/main/fe...splay=twopiece
Detail description on how RB two piece rotors are designed and built with live links (rotor shown is for Corvette Z06 front two piece):
http://www.racingbrake.com/v/main/tw..._assembly.asp?
Thank you for reading.
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/1_front_380x34mm_7b8b2a31c64b7956724de4fcc49bbee7cc2486ff.jpg)
OE Rear; 380x30mm
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/1_rear_380x30mm_e1ee808fd5a485fc829e42d203dd41adf7b2c2b5.jpg)
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/1024x768/img_2370_c139f5d02d1e6157f89f496279f4873e21591a3b.jpg)
Given no proven performance difference, I'd go OEM for looks alone (ignoring cost)!
Former Vendor
RB two piece rotor has both look and performance.
Here is a review by "mikymu" on RB two piece replacement for Corvette ZR1 CCM on Thunderhill race track:
http://www.corvetteforum.com/forums/...n-for-ccm.html
After install:
After bed-in:
RB rotors will look like this w/o getting rust like OE after use.
After install:
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/975x768/after_install_ed8b99318f16a0d7b94e0f06d3a385913305379f.jpg)
After bed-in:
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/948x754/after_bed_in_96e8bc628238dece5d7c3346cf31e76789f01102.jpg)
Former Vendor
Track duty iron replacement rotors for standard (red caliper) brakes are shipping.
380x34mm front
380x30mm rear
These are the same exact sizes as GT-R earlier model (08-11), which RB two piece rotors are favored by most serious track racers.
Purchase complete car set (front and rear) and save 10% than purchase separately. (plus free shipping until end of June)
http://www.racingbrake.com/RB-Iron-R...por-irk-05.htm
In stock for prompt shipment, street (XT910) and track (XR70) pads are available.
Our rear two piece rotors are made with forged aluminum and iron sleeve insert and is light weight and fully compatible with OE emergency brake.
380x34mm front
380x30mm rear
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/751x495/rear_rotor_w_drum_brake_1aaead46a37919979c58d5e304965c89bc1def6f.jpg)
Or these off topic CCB's: http://www.racingbrake.com/RB-CCM-Pa...por-crk-02.htm
Picking up my car Sept 24th.
I will do 4 days or Ring, 2 days of Spa and 1 day of RedBullRing the first week.
Trip #2 will be another 7 or so track days
Mid October probably need a set of pads.
Trip #3 another 7 or so.
Will have to start keeping an eye on rotors.
Maybe a 4th trip or ship it to Sebring and 48hours for 10+ days at Sebring so for sure will need rotors by then.
I hope GT3(RS) track junkies will adopt both steel and CCB rotors to compare.
My car is coming with steel setup, Id rather invest in better rotors and calipers.
Me thinks thi9s car is going to be a brake killer.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
