Brake failure at 140 mph
GT3 player par excellence
now PDK fluid in 991RS needs piwis else you cannot do it
99.9% of brake line failures I've read about have been aftermarket. Stay OEM!! Neighbor put stainless brake lines on his CLK Black Series and had a brake failure on track. An attachment point failed. Luckily he and the car were okay too. I've always had pretty good luck on track because I've stayed as close to OEM as possible. The engineering that goes into OEM parts is dramatically better than most aftermarket.
OP, glad you and the car are okay.
Hey Dwight this is Mark the guy with the other white GT3 who was parked next to you at the "day away" earlier this year. That is really scary to be coming into turn 3 with no brakes. That is the hardest braking on the course and the speeds are very high. Yes very lucky that there is easy run off and no cars in front of you.
I'm on you're side with the shop. If you pay a shop to replace your brake lines, you are certainly expecting them to do it in a way as to not cause a brake failure. The fact that they did shoddy work means that they should absolutely fix it at their own cost. Give me a brake. (No pun intended). Glad you are safe
Wow thats a shame but thank god you are ok, now the shop shouldnt be charging you if it wasnt you who installed it, first thing is it nver should have rubbed se ond a zip tie is not a permnent fix not even a safe thing to do.
IMO just talk to the owner and let them figure it out without you paying a cent.
No, it was your VERY VERY good luck.
I had a similar incident on track with my 997TT. No brakes after fast curve and before hairpin. I was also very very lucky to get away with no damage but brakes.
I believe it's the luckiest possible way to discover you have no brakes on track. No collision, no damage to yourself, other drivers, other cars and your car. It's a very good luck.
DMoore
'15 GT3
I'm still waiting to hear back from the shop involved.
DMoore
'15 GT3
DMoore
'15 GT3
Sounds very frightening. I would have thought you'd still have some braking though - I think you should have just lost one of the two curcuits (left front and right rear is one and right front and left rear the other). Maybe you knew something was badly wrong and didn't attempt to stand on the brakes given the run-off area?
