991 GT3, GT3RS, GT2RS and 911R 2012-2019
Tire pressure for the Cup2 tire at the track??
Old 04-13-2017, 09:04 AM
loopsandsounds
loopsandsounds's Avatar
Originally Posted by TRAKCAR
This means starting 22-24 on a cold day..
So to be a bit on the safe side and to keep the TPMS happy, start at 26 and bleed down to 32 after a few laps.
This^ I found I could never keep the rear pressures below 40 unless I started below 26. I also found at lower than 26 the tire is just too soft so you need to take a few easy laps to warm up the tire and increase temps. There still isn't a goldilocks cold pressure but the side bypass has helped tremendously.
Old 04-13-2017, 10:00 AM
greenhorn
greenhorn's Avatar
TRAKCAR is spot on in his suggestion.
In medium temps (17-23 celsius) I usualy find the cold pressures to go up by 0,5 bar (7psi) during a session. So aiming for a 30-32 psi hot window 24/25psi starting point seems optimum.
Once or twice went too low with the cold pressures and that results in an uncomfortable combination of overheated underinflated tires.
Wish there was a tire temp indicator on dash like the one in M4GTS. Getting the tire pressures and temps spot on is essential for an enjoyable track experience.
Old 04-13-2017, 10:02 AM
TRAKCAR
TRAKCAR's Avatar
Received 1,640 Likes on 762 Posts
THIS!! Porsche is behind BMW on this one!
Old 04-13-2017, 10:11 AM
Nizer
Nizer's Avatar
Received 1,863 Likes on 963 Posts
and rollbar and 5-lug wheels!
Old 04-13-2017, 12:34 PM
Nine1won
Nine1won's Avatar
Like Trackcar said...32 hot all 4.
LZRD GRN (05-26-2020)
Old 04-14-2017, 04:53 AM
Jono809
Jono809's Avatar
+1 for what Trackcar said...
I run 30psi hot on tracks with slower corners and 32psi hot on tracks with faster corners, just like the extra sidewall support...
Also agree about the TPMS warning lights that you get if you start below 26psi...you could start at 26, then keep bleeding after each session if the warning light bothers you, or just deal with the light like I do.
Old 04-14-2017, 08:42 AM
tstafford
tstafford's Avatar
Received 1,085 Likes on 621 Posts
Agreed.
If it helps make people more comfortable - PSDS at Barber last week had TPMS lights on all cars in the AM and simply said to ignore it. Temps came up during the day as you'd expect. If they're good with it, I am too.
Old 04-14-2017, 10:49 AM
JanStuart
JanStuart's Avatar
I was doing 30/30 at Sebring, but found the rear rolled a little much. Bringing the rear up to 32 did the trick. RE the warning light, after the first run, when you come in with hot pressure, set the Circuit to the current pressure as target, remembering to say YES every-time you start the car, and the warnings will no longer bug you. (camber at 2.5 front, 2.25 rear)
Old 04-16-2017, 09:06 PM
LandShark
LandShark's Avatar
Thanks all. I was running 33psi hot my first MPC2 track day, and pretty happy with it. Will try 32psi next time on the track.
Old 04-19-2017, 03:33 PM
Mika911
Mika911's Avatar
Surprised to see in the Sportauto article of the Manthey Racing GT3 RS that they ran 1.8bar/26psi hot pressure allround. Seems extremely low and would mean triggering the warnings. Wonder if this was a mistake or truly best for minimum laptime.
Old 04-19-2017, 03:41 PM
ms550
ms550's Avatar
Tires rollover at any less than 35 on my GT3.
Old 04-19-2017, 03:54 PM
Footsoldier
Footsoldier's Avatar
Cold PSI innthe door is often a good indicator for hot temps on the track.
MPSC2 like to be 30-32 hot.
As others have said, this is exactly right. Seems like it takes two bleeds to get stable at 30/32 then you are set for the day. Probably taking 6-8 psi out of the starting road pressures, depending on weather.
just need to remember they need to be warmed up to pressure again after an extended pit stop, and also that you need to put the air back in before driving home!
Old 04-19-2017, 08:29 PM
TRAKCAR
TRAKCAR's Avatar
Exactly, I have a little cigarette lighter powered compressor.
Old 06-09-2019, 09:00 AM
993tt
993tt's Avatar
Originally Posted by Forestek
Got this file from Michelin with the latest recommendations in pressures.
Seems higher than what most of us are running. I run around 30psi Hot on 4 tires
Going to track my GT3 for the first time on thursday so I'm looking for tire pressure advice but I find this very confusing since it totally goes against what everyone else is saying.
No one that have any comments on this advices from Michelin?
Old 06-09-2019, 03:06 PM
mdrums
mdrums's Avatar
I pretty much folllow what Michelin says. I don’t have the roll over and outside wear issues others have. I’m runing -1.7 camber. I start at 28 front and 30 rear...bleed down from there to running 33 front 35 rear hot.
Quick Reply: Tire pressure for the Cup2 tire at the track??
