991 GT3, GT3RS, GT2RS and 911R 2012-2019
Porsche's new philosophy with the GT3 according to AP
Old 04-01-2017, 06:44 AM
  #166
Zulu Alpha
Zulu Alpha's Avatar
Originally Posted by GrantG
The Cliff's Notes version: If you want to go really fast, shift when the needle gets to the red place on the tach
This is true. In order to get max power out of these engines you must shift at read line despite the power dip. Short shifting these engines is not fast.
Old 04-01-2017, 06:53 AM
  #167
Footsoldier
Footsoldier's Avatar
Originally Posted by MM3.9GT3
Senna in the rain
I raced in one of the support races that day.
Old 04-02-2017, 05:44 AM
  #168
randr
randr's Avatar
Grant thanks for pulling the gear ratios together - see below for various P car torque curves including the 991.1 GT3. The shift points and ratios make perfect sense (as you would expect) when you view them relative to the torque curves (assuming a run out to the redline before change) e.g. GT3 - shift from 1st to second at redline, 2nd starts at ~ 5500rpm, for the GT4 2nd is at ~ 4500 rpm and the 991.2 C2S 2nd is at ~ 4000 rpm.
GT3 redline in 1st @ 52mph, 2nd gear rpm at 52mph ~ 5500, 332hp in second gear at 5500rpm - its easier to look at the graphs
GT4 redline in 1st @ 48mph, 2nd gear rpm at 48mph ~ 4500, 257hp in second gear at 4500rpm
C2S(.2) redline in 1st @ 43mph, 2nd gear rpm at 43mph ~ 4150, 296hp in second gear at 4150rpm
I was bored and I believe a picture is worth 1000 words. All in the name of power under the curve.
Has anyone found a 991.2 GT3 torque curve.........I suspect it will be very interesting
Old 04-02-2017, 01:12 PM
  #169
Drifting's Avatar
Received 1,315 Likes on 689 Posts
.2 GT3 vs .1 RS
black torque and red HP is .2 GT3
Old 04-02-2017, 03:18 PM
  #170
armbar
armbar's Avatar
Here is a good video that I hope will contribute to the discussion:
Old 04-02-2017, 06:28 PM
  #171
GrantG
GrantG's Avatar
Received 5,054 Likes on 2,850 Posts
Good one!
Old 04-02-2017, 07:02 PM
  #172
Nick
Nick's Avatar
Generally, you're either good in shifting and using H&T or you're not. There is no in between. Most should save themselves the embarrassment and get PDK-S and be done with it. Let the computer manage the shifting while you do the driving.
Old 04-02-2017, 07:45 PM
  #173
TRAKCAR
TRAKCAR's Avatar
Received 1,661 Likes on 772 Posts
Can't do too much harm with the autoblip..
Old 04-02-2017, 08:15 PM
  #174
Nick
Nick's Avatar
Quite true but then what is the point of MT?
BTW, the recommendation for maximum performance that you should shift at redline is difficult to do. If you wait until redline, your shifting too late because of the delay in your reaction time. If you do it sooner, then you missing the optimal shift point. Good luck in making that work.
Old 04-02-2017, 08:18 PM
  #175
GrantG
GrantG's Avatar
That fact that it's not easy without concentrating is part of the attraction...
Old 04-02-2017, 08:46 PM
  #176
TRAKCAR
TRAKCAR's Avatar
It's hard enough for me pulling the flappy at the last moment without hitting the rev limiter LOL.
Old 04-02-2017, 09:20 PM
  #177
Nick
Nick's Avatar
There is the auto setting.
Grant, your comment proves my point. Very few are good at it and most are bad. FWIW, I am in the bad category and embraced PDK with relish.
Old 04-02-2017, 09:32 PM
  #178
GrantG
GrantG's Avatar
With the .2 GT3 manual you have a little more time to shift, since there are only 6 ratios where you have 7 and the redline is a bit higher which is good for another blink
Old 04-02-2017, 10:17 PM
  #179
bronson7
bronson7's Avatar
Peter, if there's an option of a MT with the .2GT3RS, would you choose it over the PDK S?
Old 04-02-2017, 10:22 PM
  #180
TRAKCAR
TRAKCAR's Avatar
Only at Daytona would one need 6th. I guess I could save a tiny bit of time slapping the shifter into auto VIR the 4-5 gear shift on the back and front straight at Sebring but I don't like auto in most corners..
I'm sold on PDKS unless I have an older lighter car and move to where the roads are fun..
Quick Reply: Porsche's new philosophy with the GT3 according to AP
