USCTrojanGT3's UltraViolet Porsche 991 GT3 RS Track Prep at BBi Autosport
GT3 player par excellence
Basic Sponsor
Next, we installed our BBi Stage 2 StreetCup Track Suspension Package to improve the handling. This package upgrades the factory springs with an improved linear rate springs and replaces the factory thrust arms and sway bar end links with the our adjustable arms that uses spherical bearings.
Suspension Upgrades
Springs Upgrade Kit
Complete Package Includes:
BBi 991 GT3 StreetCup Adjustable Thrust Arms
BBi 991 GT3 StreetCup Adjustable Thrust Arm Bushings
Tarrett Front and Rear Adjustable Sway Bar End Links
[/FONT]
Suspension Upgrades Installed
Suspension Upgrades
- BBi Porsche 991 GT3 Street Cup Spring Package
- BBi Adjustable Thrust Arms Front Pair
- BBi Adjustable Thrust Arm Bushings Front Pair
- Tarett Engineering Adjustable Sway Bar End Links Front & Rear
- BBi StreetCup Track Corner Balance & Alignment
Springs Upgrade Kit
- 2 Coilover Spring (Front)
- 2 Coilover Spring (Rear)
- 2 Coilover Helper Spring (Front)
- 2 Coilover Helper Spring (Rear)
- 2 Upper Spring Rest (Rear)
- 2 Lower Spring Rest (Rear)
- Connects the Lower Control Arm to the subframe
- Provides precision caster adjustability
- Spacers included for setting stock or anti-squat and anti-dive configurations
- Eliminates factory rubber bushings for improved suspension feedbacks
- Provides two eccentric mounting points
- Used to adjust for increasing or decreasing wheelbase, and adjustable caster.
- A must-have for extended lower control arms (GT3 control arms or eccentric monoballs) to correct for unintended caster change
[/FONT]
- Simple bolt in replacement for the factory drop links
- Left & right hand threaded rod ends allow for simple length adjustment to eliminate swaybar preload
- Correctly sized, precision, Teflon-lined rod-ends for smooth and quiet operation, long life, and high reliability. No wear and rattling problems, like those seen with other designs, due to undersized or low quality rod ends
- Eliminates the factory compliant plastic drop link bushings that deflect under loading and quickly wear out
- High misalignment, stainless steel spacers allow for superior bind free operation and corrosion resistance
- Precisely connects the stock or adjustable swaybar to the front strut assembly for improved feedback and swaybar response
- Overall length is adjustable to accommodate either stock or adjustable swaybar requirements
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
^^^ The materials on the new factory rotors are impressive. WAY better than the 997 stuff.
On the brembos, I think he did 2.5 days on the car, and there were no stress or crack marks on the rotors at all. Granted button willow is not that hard on brakes.
On my car (not the same pace as a 991rs obviously) the type 5 fronts have 10 days and still look fresh. Martin is running a few seconds a lap faster than I am, primary braking zone speeds are actually similar, he's just got more sack than I do in some of the high speed areas.
Right.
Without hijacking this thread, I think slotted are better but the 991 OEM rotors are lasting very long, I have 15 days on my second set and even using up used pads and hammering the brakes very hard at Sebring Homestead and PBIR (Derek Bell set all 4 corners just about on fire)they are still not cracked through but they are looking pretty tired.
My rears are original and looking fine.
Awesome pics Martin! Mr Purple FTW!!
I put the slotted rotors on before the first track day. I did 14 sessions with the car and the rotors still look pretty much new. I did have to get used to the RT10 brembo pads as they don't have as much initial bite as what I'm used to with the Endless ME20s. My AP rotors in the front on my GT4 lasted 24 track days and the rears still look good.
Right.
Never mind me, I've only heard good things about the Brembo discs, very popular with the regular track guys here
