Incoming RS...outgoing GT3: Returning to stock, a few questions
I put a feeler out on my car built with DE mods but haven't had any legitimate interest so I'm planning on returning my car to stock. I searched but couldn't find anything on a few of these questions so I figured I'd ask.
1. Does anyone know what carpet pieces need to be ordered/part numbers? I have the BBI bar and cut holes in the lower bench and upper carpet.
2. I have the TPC bypass pipes, will these bolt onto the RS?
I don't have the price for the carpet, but my guess is that it isn't cheap. I would keep the bar in case you are not going to use it in the incoming RS. The bar shouldn't be an issue for most buyers, most likely vice versa.
As for the pipes, should fit the RS without issues.
GLWS!
could you swap the new carpet with the old? (if using the bar in the RS)
I thought about this but the lower carpet that goes over the tunnel seems to be one piece. I guess I could try to see if they could come apart so that I could reuse the carpet...
Have you talked to Jerry at BBI? I asked for this info before purchase and he sent me the info below. Unfortunately no parts numbers but he may have that as well.
