Twin Tuesday Part II. Silver Porsche 991 GT3 RS's Returns for Full BBi Track Package.
Basic Sponsor
Attachment 1344394
Twin Tuesday Part II. Silver Porsche 991 GT3 RS Returns for Full BBi Track Package
(Click on images for higher resolution)
Greetings Rennlisters,
Continuing from our last "Twin Tuesday" post, this pair of nearly identical Silver Porsche 991 GT3 RS returns to BBi Autosport for to get the our complete StreetCup Track Package. Like inseparable twins, we installed our BBi 991 GT3 harness bars into both of these cars at the same time during their last visit at our facility. For their second visit, we will be installing our all new billet aluminum suspension package and exhaust bypass onto both cars. Please stay tuned for updates!!!
Upgrades for Part II
Engine
• BBi 991 GT3 Street Cup Exhaust Bypass
Suspension
• BBi Porsche 991 GT3 Street Cup Billet Aluminum Monoball Control Arm Package
• BBi Porsche 991 GT3 Street Cup Spring Package
• BBi StreetCup Competition Corner Balance & Alignment
- Jerry@BBiAutosport.com
Engine
Suspension
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Basic Sponsor
Here is a quick look at all the stock suspension components that we will be replacing.
Stock Front Suspension Components
Stock Rear Suspension Components
Basic Sponsor
Now we will outfit this car with our complete BBi 991 GT3 Street Cup Suspension Package to improve the handling response. We will upgrade the factory springs with an improved linear rate springs and replace the factory arms and links with our billet alumimum monball arms to eliminate rubber deflection.
BBi Billet Rear Control Arms
Adjustable Sway Bar Endlinks
Spring Package Matched Specifically to the OEM Dampers
Installed on OEM Dampers
Detailed shot of Top Mount
Detailed shot of Bottom Mount & Helper Springs
BBi 991 GT3 StreetCup Adjustable Thrust Arms
• Connects the Lower Control Arm to the subframe
• Provides precision caster adjustability
• Spacers included for setting stock or anti-squat and anti-dive configurations
• Eliminates factory rubber bushings for improved suspension feedbacks
BBi 991 GT3 StreetCup Adjustable Thrust Arm Bushings
• Provides two eccentric mounting points
• Used to adjust for increasing or decreasing wheelbase, and adjustable caster.
• A must-have for extended lower control arms (GT3 control arms or eccentric monoballs) to correct for unintended caster change
Basic Sponsor
Front Suspension
Front Spring Kit
BBi Adjustable Thrust Arms, Adjustable Thrust Arm Bushings, Front Lower Control Arm Spherical Bearing Flange, Tarrett Adjustable Sway Bar Endlinks
BBi Adjustable Thrust Arm Bushing
Rear Suspension
Spring Kit & Rear Billet Aluminum Upper Wishbone & Trailing Arms
Rear Lower Billet Aluminum Trailing Arm & Tarrett Adjustable Sway Bar Endlinks
Rear Lower Control Arm Spherical Bearing Flange
Front Spring Kit
Rear Suspension
Basic Sponsor
Next, we swapped out the factory primary side mufflers to uncork the engine and reduce 40 pounds of weight behind the rear axle.
Basic Sponsor
Now we proceed to give the second twin Silver 991 GT3 RS the same BBi treatment.
Quick look again at the stock front and rear suspension components on the driver side
Non adjustable factory front thrust arms with rubber bushings
Front inner bearing with rubber bushings
Rear
Rear upper control arms
Factory Rear Lower Trailing Arm
Rear
Basic Sponsor
Thank you guys! After our dialing the setup, it is 1/2 inch lower in the front and 3/8 in the rear.
Basic Sponsor
Now we proceed to install the front suspension components starting off with our spring package.
Side by side comparison. Left side is the OEM damper with the BBi spring kit installed.
Front suspension assembled.
Front spring kit installed on car
Front Thrust Arms & Bushings
Adjustable Way Bar End Link
Basic Sponsor
Now we proceed to installing the rear components starting off with our spring package.
Rear suspension assembled.
Rear spring kit installed on car
Rear billet aluminum control arms
Basic Sponsor
BBi StreetCup Exhaust Install on 2nd Silver 991 GT3 RS
OEM Side Mufflers to be deleted
BBi StreetCup Cup Exhaust Install on 2nd Silver 991 GT3 RS
Close Up Shots
Close Up Shots
