Plug, patch, or new tire? (Brand new RS)
If you aren't hooning the car then maybe a patch, but my guess is no tire store will do the repair for you. I had a very similar issue on my R8GT while on a road trip and no one would touch it and it was three days to get a replacement tire. I ended up plugging it myself and driving a 1000 miles back to Houston, where I put a new tire on.
GT3 player par excellence
very close to side wall
patch ok, but I would put new tire.
IF in unlikely event i
it fails, damage is way bigger.
why risk
why risk
Patch it as it is not on the sidewall.
Asking obvious question. Is it leaking? You remove the screw?
Proper repair is pull tire and do a patch that has a plug on it from the inside. These are fine.
However that screw looks a little close to the sidewall as serge mentioned.
Had very similar, it actually was a short screw that did not puncture, only went into tread.
If nail dead center would patch and run it on track. If closer to sides problem is if you track and lower tire pressures patch mite peel off(been there done that). If street only I patch it. Mike
