991 GT3, GT3RS, GT2RS and 911R 2012-2019
Another 410x40mm MovIt CER kit installed on a 991 GT3
Old 05-31-2017 | 11:35 PM
  #31
GrantG's Avatar
GrantG
Carbon/Carbon? I have a friend who is using this on his VERY lightweight early 911 (licensed for the street at 1,5xx pounds with 3.0L Flat-6) - rotors adapted from competition carbon/carbon setup and he loves them despite the reputation that they don't work cold (he can lock them cold without power assist).
Old 06-01-2017 | 02:22 PM
  #32
EST's Avatar
EST
Originally Posted by C4SGRPDK
can't wait to see what it is!
Old 06-01-2017 | 08:16 PM
  #33
qbix's Avatar
qbix
Would you be able to provide weights of the rotors and calipers?
For OEM PCCB are the Movit rotors direct replacement?
Old 06-01-2017 | 08:26 PM
  #34
MovIt Brakes USA's Avatar
MovIt Brakes USA
Yes we can provide weights of the different components. please email me directly for this information.
The OE Replacements are a direct fit both PCCB and Steel will be available, yes. :-)
Old 06-01-2017 | 11:17 PM
  #35
qbix's Avatar
qbix
Thanks.
Why don't you put the weights here? Other rennlisters would be interested as well I am sure.
How is that possible that irons are direct replacement as well? They have different diameter and are thinner I believe.
If I understand it correctly for PCCB you can just swap the rotors and no other modification is needed?
What is the cost of refurbishment per corner and how would I know that it's time to do it? Do you provide minimum rotor weight as well?
Are those brakes TUV or CE certified?
Old 06-02-2017 | 12:46 AM
  #36
TRAKCAR's Avatar
TRAKCAR
Anyone have a couple hundred track days on a set?
It would take a while but at this price, you assume to move the kit to the next car.
Do you think it's feasible to just use them in the front?
OEM rears seem to last forever, or 80ish track days.
Quick Reply: Another 410x40mm MovIt CER kit installed on a 991 GT3
