Introducing.....PURPLE HAZE
#77
Thanks, loving it.
#83
https://rennlist.com/forums/997-foru...ace-gauge.html
Thanks.
#84
Wow! Super awesome specifications. You have the best looking RS I have seen. Thanks for the fantastic pictures. Congratulations !
Amazing Akra Race exhaust! It's great that there's no CEL from them with the O2 sensor sleeve. Do you think that once you open up the throttle a bit after running in that you might see CEL?
Mark
Mark
#88
Mark
Mark
Thanks!!
#89
Whoa, epic steering wheel. Definitely makes the car feel that much more special!
#90
Just done with this. Replacing the exhaust did not require taking the bumper off nor will installing rear view camera so I didn't want to unnecessarily remove the rear bumper. With the aid of painter's tape and lots of caution/patience, I was able to remove the reflectors (impossible to not break them in the process) and replace them with the painted ones. Not a scratch. I like the painted reflectors because from a distance (last picture), the rear looks cleaner and wider. I did not use that big screw driver, BTW and yes, my garage is cluttered.
