How often do you get alignments
I've found that front toe angles on my car don't stay put after just 1 autocross, resulting in toe out and veering to 1 side when driving straight. It seems excessive to get an alignment after every event and I rarely drive it on the street. I am running a track alignment of ~2deg negative camber f/r, ~9.5deg caster, 02' toe in f, 10' toe in r.
I am thinking it could be due to the bumpy autocross surface because I haven't noticed issues from tracking it.
How often do you guys get an alignment done?
The last thing is make sure the equipment that there using is consistent and calibrated. I only use an mechanical set up for toe much more repeatable. Just spent 3 hrs yesterday setting the rear toe on my GT4.. carl
http://lshapedgarage.blogspot.com/20...asurement.html
