Ferrari 458 vs Porsche 991 GT3
Mags have gotten it to 11.2
But yeah so many variables in terms of elevation and track prep. The fact that a NA 6 cyl gt3 is running close to a gtr's times is nuts
thats true. The GT3's main advantage is the cup tires and rear engine letting it launch so hard.
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
My GT3 always had the same trap as that 458. Personal best was 11.2 at 123.5 mph against a GTR nismo 11.3 at 123.8 mph.
I don't know how the 458 will do in a half mile but I tried the special in a half mile event and it did 158.5 mph while the GT3 did 153 mph (156.5 without the wing)
Originally Posted by TkTk
Yes, otherwise you wouldn't get a perfect launch.
Like I said it's been long time(20+years)so I guess things have changed.
Basic Sponsor
Well it's been many of years from my last trip to the stripe but I was always told back then if you had tread not to do the water box cause you wouldn't get all the moisture out before launch. Should only water with slicks.
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
The conditions that night was horrible. It was 85 degrees with high humidity. Also, I think 11.3 is very possible if I reduced the tire pressure to 27 psi. I was running at 38 psi all night.
Also, "hypothetically" speaking, if we were doing roll racing on the freeway from 60 to 160 mph, 458 pulls like 10 cars.
But this made me realize how bogus Ferrari magazine times are. There is no way 458 can run 10.9 (road and track). My buddy ran 6 times all with PS button on his 2013, but the best time he got was 11.63. He had no chance of beating my GT3 that night.
Will it be the same outcome by either pulling in both paddles and rev the motor to 4 - 5K as, mashing the gas and break simultaneously then releasing at the same time?
I was running Trofeo R at the time and from what I noticed on the track and on the strip is that they have bad grip if you didn't heat them enough.
