991 GT3, GT3RS, GT2RS and 911R 2012-2019
Tire Grip Question - Lost Traction Today
Old 08-04-2015, 07:00 PM
sgroer
sgroer's Avatar
Received 1,016 Likes on 282 Posts
Originally Posted by rockitman
Yes I heard from another participant I met last weekend that you are pretty tough to keep up with, especially on public roads..
There were times we had to take a deep breath and ratchet it all back. 40 gt3s in the smokies has quite an effect on you.
Fwiw I'd say Lodi and I were very responsible today. So I blame the other 38 participants.
Old 08-04-2015, 09:23 PM
tqevo
tqevo's Avatar
I try to keep pressures at 30F/32R hot... usually start 26/28 cold. Anything higher than 33 tends to get greasy.
Old 08-04-2015, 09:31 PM
allans
allans's Avatar
Pressures to high. Start at 30 and bleed back down to 30 at each stop. Don't forget to bring them back up to 30 cold, after your done and they are cold. Also, tire grip is probably down 30% from new. Need to replace. Best, Allan
Old 08-05-2015, 12:49 AM
mwar99
mwar99's Avatar
Keep in mind we were following you for a day and a half!
Old 08-05-2015, 01:17 AM
meaker
meaker's Avatar
Default Tire Grip Question - Lost Traction Today
Lodi, I remember during the smokies we were around 36 with a few times hitting 38. I believe I remember you letting a tad out at a stop cause you were hitting 38. I'm guessing that was your problem this time. Otherwise the tires are just toast. Do you track your car a lot? I was told you can't heat cycle on public roads. That it takes track temps to get a cycle but I think the smokies drive got a few heat cycles.
Old 08-05-2015, 08:41 AM
sgroer
sgroer's Avatar
You weren't following me. You were pushing me from behind.
Old 08-05-2015, 10:44 AM
mwar99
mwar99's Avatar
Uh huh...
Old 08-05-2015, 11:00 AM
meaker
meaker's Avatar
I just wanted to hear the GMG up close..
Old 08-05-2015, 11:02 AM
sgroer
sgroer's Avatar
Uh huh...
I felt I had no choice... I hated every minute of it.
Old 08-05-2015, 12:36 PM
mwar99
mwar99's Avatar
Peer pressure is a horrible thing.
I guess it's a circular issue as I felt the need to keep up, which then gave you no choice but to go because you felt you were being pushed...i guess you might call that a win win situation.
Old 08-05-2015, 02:34 PM
hfm
hfm's Avatar
28 fronts, 32 rears cold. Set by dealership to OEM spec a few months ago. Hot, I noticed the rears went up to 38.
Dan (does a FYI)
Quick Reply: Tire Grip Question - Lost Traction Today
