emergency wheel tightening
Yes I would run it up to the stop mark, to make sure you exceed the specified torque. It is safer to be slightly over than being under torqued.
Thanks for sharing your experiment results. But for the emergency procedure, don't you still need a torque wrench to apply the initial 100 N*m?? So this is an emergency procedure for when you have a 3/4" socket wrench, and a torque wrench capable of 100 N*m, but not 443 ft*lbs? Seems odd.
You can use the 3/8" or 1/4" adopter to use with the small torque wrench to apply the initial 74 ft.lb torque, but you absloutly right you can't use to apply the full 443 ft.lb torque and must use a minimum of 1/2" & preferably 3/4" for the breaker bar to loosen or tighten the nut. Mark
Yes I'd use the small adaptor to apply the initial torque. I think you could find a small torque wrench and 1/2" or 3/4" breaker bar in an emergency however finding a 3/4" torque wrench may be more difficult.
Wouldn't the yield strength likely be based on tension? The conversion from torque to compression on the nut would be complex and the failure would more related to the compressive strength or shear strength and cross sectional area of the nut would it not?
The estimated stresses for a given preload are fairly easy to predict or calculate if no grease or anti-seize materials are used on the threads. All you need to know to calculate the tensile or compresive stresses, is type of the materials used, the physical diameter of the bolt & nut, and seating dimensions including the thread details such as pitch, etc which can be easily attained by physical measurement of the bolt & nut, and finally the coefficient of friction of the threads and seating area which is what really complicates the estimation due to the presence of grease or anti-seize compound plus few other factors, but an engineer can usually make some safe assumptions about the coefficient of friction based on experience and is able to get a rough estimate of the stresses for a given torque value, while understanding the results can vary by as much as (plus or minus) 15% error in the estimate as a result of his or her assumption of the coefficient of friction. So when an engineer estimates that you can torque the bolt safely to 1000 ft.lbs without causing permenant damage to the bolt, nut or wheel, you can safely attest that torquing the wheel to 600 ft.lbs which is so much lower than the estimate, should not cause any permanent damage to these component. That's all what I was trying to say, and that the additional 100 ft.lbs over-torquing or even 150 ft.lbs as a result of using the Porsche emergency procedure should not be of any concern to us, and There is no need to change anyone plans to find the correct size torque wrench to re torque the wheel to the correct lower specified value. Personally I feel safe to drive & track my car indefinitely with the higher torque value after performing the Porsche emergency procedure. Mark
Are you coming today or tomorrow to PIR. There are several events taking place this weekend. Mark
