Clear Third Brake Light Now Available?
It looks like the RS configurator is showing that this is part of the clear tail light option for the RS. Anyone know if this will fit the regular GT3?
Received 5,407 Likes
FWIW in a number of states, including Cali, you will be in violation unless you have some red reflective material on rear/side . Standard rears already have red reflectivity built in--but since I don't think clears do, you technically gotta keep the red reflectors with them.
They probably used the light from the Turbo as they already have both red and clear. It didn't need to fit into the wing so I suspect they had a great size tolerance.
