After I have changed a tire due to leaking air - I took the car out for a spin for the first time in 10 days...
The weather got nicer, and outside temp was around at 50F-ish, and I found a nice road and pushed the car around 5000 RPM through out ~7th gear for little more than 100 miles. I made occasional stops and when I came back home, I found this;
black tar? like substances
I should have taken more pics... there were much worse parts around the body. Inside the wheel arch, especially at the end of fenders, it looked like a wall from a fireplace;;
The traces of the black substances were on doors, around door sills and even there were some on the rear lower side of rear spoiler...
Tire pressure was around 30-ish front, and 32-ish back; The car's mileage is close to 600 mi.
From observing the characteristic of the splash, it looked like the compounds from tire is sticking on the body panel...Is this normal?
