But the valves are attached before the entry to center muffler , I am assuming center muffler is stock. TpC design from what I can tell is similar to bbi side pipe but has a valve built in. Side mufflers due to their size provide most muffling or noise reduction. I cannot understand how adding a valve before stock center muffler helps.
I think what he's saying is since the upper pipes (valves) that connect to the stock center muffler are still there you're still able to utilize the baffling and section in the center muffler. Whereas a side muffler delete with a single pipe you're fully bypassing all of that.
sometimes the track map is posted the friday before, other times you just walk it and learn it by driving it. i think people make a bigger deal out of it than it really is
