991 GT3, GT3RS, GT2RS and 911R 2012-2019
Removing rear wing
Old 03-09-2015, 11:44 PM
avi8tir
avi8tir's Avatar
Default Removing rear wing
Im about to send my rear wing off for some paint work. Assume removing it is as easy as popping off the 4 rubber hole plugs and unscrewing with the appropriate torx?
Old 03-09-2015, 11:48 PM
MileHigh911
MileHigh911's Avatar
yes!! The first time removal, the torx screws are quite tight. Then it is easy
Old 03-10-2015, 10:37 AM
FastLaneTurbo
FastLaneTurbo's Avatar
You will also have to unplug the brake light harness connector. Easy on and off.
Old 03-13-2015, 04:43 PM
avi8tir
avi8tir's Avatar
How do you unplug the rear light? I cannot seem to find the clip.... thanks!
Old 03-14-2015, 12:53 PM
avi8tir
avi8tir's Avatar
Any input on the wing brake light?
Old 03-16-2015, 09:12 PM
avi8tir
avi8tir's Avatar
surprised that no one has done this before.... have I stumped the forum for the first time EVER??
haha.
Old 03-17-2015, 10:25 PM
FastLaneTurbo
Open the rear Engine lid. Locate the wiring harness coming from the brake light. Trace the wires with your fingers, then follow it up into the Right Rear Wheel Body enclosure. You can locate the connector with your fingers without seeing it hidden away up there. Then, unplug that connector and you can remove the Wing. If you have difficulty, just let any good Porsche mechanic do that for you. Shouldn't take him more than a few minutes to unplug it for you.
Quick Reply: Removing rear wing
