PSC2 vs Trofeo R speed difference
#46
This is a good guide to get started: http://www.tirerack.com/tires/tirete...nd_Feeding.pdf
Really applies to any set of tires, very good introduction to correct track setup.
#47
dntlvet
Yes, you need somebody in the pit lane to read the tires. You need to do this when you immediately come off the track otherwise the tires equalize the temp across the tread. Take three readings with a probe type pyrometer across the tread. These readings will give you a good idea on your set-up and overall tire temp=pressure.
#48
Can we get some updates on the Trofeo R after a summers use? I am heavily debating starting with these on my GT3 instead of MPSC2's and want to know how fast they cycle out? and just peoples overall impressions after a summers use. Thanks
#51
I just did some comparisons over the past few months with the Trofeo and the Cup2 at Road Atlanta. Here is what I found. The Trofeo had approximately .1 G more grip in both lateral (cornering) and longitudinal grip (braking). Throwing out some outliers the Trofeo consistently got 1.5 Gs of lateral grip, compared to 1.4Gs for the Cup2. In braking, the Trofeo averaged 1.7 G's, compared to 1.6 G's for the Cup2. I ran my best times on the Trofeo by about .7 seconds (1:34.2). Given I'm not as consistent as a pro and clean laps are sometimes hard to come by, the other way I looked at it was with my best composite times. My best composite with the Trofeo was 1:31.5 versus 1:32.9 with the Cup2. After looking at my data post-facto, my biggest regret is that I didn't push the Trofeos harder given the additional grip. I'm going to try another set after I wear out the Cup2s, but that probably won't be until February or March, given the weather. I do agree with Sam's comments that the Cup 2s seems to prefer more slip angle. Wear was about equal before they both lose grip. If you don't care about maximum grip, I think you can get more cycles out of the Cup2s. The Trofeo rears wear out much faster than the fronts and will definitely cord before the Cup2s. My overall impression is the Trofeos are better and I will probably stick with them unless an N1 version of the Cup2 comes out next season and is markedly better.
#52
Received 1,224 Likes
#53
Thanks. What about longevity? Did you have a chance to compare that at all? We have some very different experiences on this board - most I've seen suggest that Trofeos provide same number of track days and MPSC2, assuming MPSC2 are replaces fronts and rears together (5-6 days), but some indicate that Trofeos last only 1/2 of the time MPSC2s do.
#54
#57
Platinum Dealership
I have found that the Trofeo's cord a lot earlier than the michelins- that's the only downside to the tire is that you can't really "squeeze" anything else out of them, once they're worn, they're trashed.
#59
Premium Sponsor
Let us know! We have them in stock
TAG MOTORSPORTS
866-793-5490 x1192
web: www.TAGMotorsports.com - email: sales@tagmotorsports.com
Authorized Dealer For: HRE, Vossen, TechArt, AWE, Bilstien, KW, Akrapovic, Capristo, Fabspseed, BBI, Vorsteiner, Milltek, 1016 Industries, BBS, Brembo, GMG, H&R, Pirelli, Michelin, Hankook & more.
TechArt & AWE Tuning's #1 Volume Dealer Nationwide
866-793-5490 x1192
