Received my PDK sports button , but sports mode not working
I finally got the PDK sports button installed by the dealer and looked fine . Unfortunately the mapping or something is wrong , on auto it does not DOWNSHIFT !!!! And even while driving it on any gear and on any throttle input it does not go up to a higher gear unless i reach 9000 rpm .
Does anyone have a mapping of the software on gear changing ?? as the dealer is going to inspect this and probably redo the whole remapping if this is the problem . I would like to make sure my car is synchronized properly when pdk sport is in auto mode .
I can't believe porsche reached to this level of quality inspection.
In Sport mode, the PDK will not downshift no matter how slow you are in a higher gear or how deep into the throttle you go. If you drive in a spirited way, it won't shift until close to or at 9K. If you drive in a very relaxed way, it should shift before 9K but usually not before 4 or 5. Is your car taking you to 9,000 even if you are driving very conservatively?
I think you are referring to the lack of kick down in sport mode upon application of throttle. The problem op is describing is that the car wont downshift in sport mode period, even when he applies brakes and slows down. Further regardless of type of throttle input he has upshifts at 9000 only.
OP in sport mode the up shift you reference is normal. It will hold to 9000 rpm to shift. Are you saying that when you decelerate it stays in the higher gear and won't downshift at all as the RPM drops? If it doesn't downshift at all as you stated, does it stall?
Are you sure that's what the OP means?
