991 GT3, GT3RS, GT2RS and 911R 2012-2019
Iphone 6 and PCM
Old 10-02-2014, 12:05 PM
chizi
chizi's Avatar
Location: Dubai, United Arab Emirates, United Arab Emirates
Default Iphone 6 and PCM
Since I got the iPhone 6, PCM has not been working well with the phone especially when connected with Bluetooth and try to answer a phone call or talk during a call PCM just won't connect the call. It shows my phone connected. I can listen to music through AUX Bluetooth no problem. But no phone calls
Old 10-02-2014, 12:11 PM
Daniel L
Daniel L's Avatar
Supposedly the issue has been fixed in 8.1. It should show up any day now.
Old 10-02-2014, 12:18 PM
WernerE
WernerE's Avatar
I was able to pair my iPhone 5s running iOS8 with my 997.2 911 but cannot pair iPhone 6 with either my 997.2 or my 991 911s. The problem is not limited to Porsche, as BMWs have the same issue.
Apple supposedly did not change much (if any) with Bluetooth under iOS 8. Porsche service advisors are at the mercy of Porsche to release a software/firmware update.
Zulu Alpha
Zulu Alpha's Avatar
I have IPhone 6 Plus and it works just fine.
Edit: wife just told me her iPhone 6 also didn't connect via Bluetooth in her C-Class.
Must be a 6 issue. Weird.
Edit #2: I just tried my wife's iPhone 6 on my PCM and it worked fine. Even made a call.
Old 10-02-2014, 12:23 PM
WernerE
WernerE's Avatar
Not sure about your timeline 8.1, as I've heard 2-3 weeks, at best. Let's hope it can happen at Apple's end, so we don't have to wait on the car manufacturers to accommodate 8.0.2.
Old 10-02-2014, 03:56 PM
Terrence
Terrence's Avatar
Works for me.
Old 10-02-2014, 06:24 PM
Mike in CA
Mike in CA's Avatar
Good to know. Thanks.
Old 10-02-2014, 10:06 PM
///MMB
///MMB's Avatar
No issues with my gt3 or 2014 M6 using my iPhone 6+ iOS 8.0.2
Old 10-02-2014, 10:11 PM
brass4321
brass4321's Avatar
My iPhone 6+ calls work fine but I can no longer control music apps from PCM (volume, skip, etc). I have 8.0.2 and apparently this is a widespread problem, not just for P-cars. It will eventually get fixed, maybe the next PCM gets Apple CarPlay built in.
Old 10-02-2014, 10:31 PM
ipse dixit
ipse dixit's Avatar
Received 11,738 Likes on 5,126 Posts
iPhone 6, iOS 8.0.2
No problems (but then I have a C4S).
Old 10-03-2014, 01:11 AM
Spyerx
Spyerx's Avatar
Received 1,806 Likes on 1,101 Posts
Same here. Bt fine. Music plays fine. Can't control from PCM. This is in a 13 cayenne which has newer PCM system
Old 10-03-2014, 01:18 AM
WernerE
WernerE's Avatar
Is this possibly a carrier issue? I am using AT&T and I don't have hands-free on any of my cars with iPhone 6 running 8.0.2. I find the inconsistency very strange. I even deleted my old devices, thinking that was causing a problem.
Old 10-03-2014, 07:25 PM
strandolph
strandolph's Avatar
I have an AT&T iPhone 6 with 8.0.2 and am having the exact same problem in my 991 C2. It worked fine with 8.0.0. Just another data point. I'm just now surfing around trying to find information about it...
Steve
Old 10-04-2014, 12:51 PM
strandolph
strandolph's Avatar
The solution I found was to "Reset all settings" then delete and re-pair your phone. That solved my problem for now.
Old 08-04-2015, 03:08 PM
odwa
odwa's Avatar
Did a search and couldn't find a solution. iPhone 6 with 8.4 software having problem with volume to caller, they cannot hear my conversation but I can hear them fine. I can place and receive calls and the rest of usage seems to work fine, what am I missing?
Quick Reply: Iphone 6 and PCM
