Why not optional 21" wheels?
Neon underglow FTMFW! New exclusive option for $2200!
Hopefully OZ Racing, HRE and Forgeline are ahead of the curve and already have a 991 GT3 wheel (front and rear) ordered as a spare part; if they build a 19, that gives us access to Hoosiers.
Paradoxically, the PCCBs will be too big to fit inside 19's. Those wheel makers need to design a one-piece wheel with a recessed barrel to clear that freight train of a caliper on the 991.
Maybe the 19's will even have trouble clear the rear steer hardware, which would explain why Porsche went to 20's. There's no other explanation on the planet for going to 20's.
Does anyone happen to already know the offsets of the GT3 wheels?
I have the German GT3 catalogue here and this is what it says about the wheels:
Front Axle: 9 J x 20 ET 55
Rear Axle: 12 J x 20 ET 47
Here's a link: http://files3.porsche.com/filestore....8-478a67ac9487
Suzy991
Porsche offers multiple design wheels for the 991 cars, except the GT3.
Why can Porsche/VW not offer optional 21" wheels, forged wheels, different shapes? Most of the GT3 buyers end up spending $$$$$ on aftermarket wheels, when VW Group could manufacture a quality wheel while standing behind the Center-Locks warranty.
Buying aftermarket CL wheels is a risky business, and in case of failure, these wheels void the factory VW warranty.
It will need Hoosiers. Hence 19's. But 410mm PCCBs under 19s?
PCCB calipers with spacers or specific wheel carrier?
So I think it's going to be PFCs or Movits with the stock red calipers.
Suzy991
Suzy991
I should have looked for the English version of that document.
410mm 390mm PCCBs has me wondering if Porsche has different wheel carriers or just offset spacers for the calipers.
I assume the calipers are fixed bridge and will have the same issue of needing to be studs or at least TIME SERT to endure repeated pad swaps.
I think it was unimportant to put 18's on the 997.2, but I think its really going to be mandatory to "downsize" to 19's on the 991, at least until there's Hoosiers or something for the track.
We'll need to see the dimensions of the calipers, but it's probably doable with the right wheel. I'm running 17" wheels over 350mm PCCBs; 19s over 410s would nominally have 4.5mm less clearance, but it'll all come down to the specific wheel and the caliper design.
Seems just a matter of time before hoosier does develop something.
For what it's worth, I've got Dunlop Sport Maxx Race tires on 19s at the moment, and honestly the tire sidewalls are so soft it feels like they need 20s.
I don't think looks are solely driving the larger wheel diameters. Instead I think it's a combination of ride and performance. A larger tire OD will improve both ride and grip (mostly braking/ acceleration?). Softer sidewalls also help ride, but then the only way to keep transient response reasonable is to increase wheel diameter. They've been playing this game for two decades, and as tires evolve it seems they have a way to go. However you need tires designed for these bigger rims to make it work, and vice-versa. Hence the Dunlops not feeling too hot in transient response on smaller rims, at least in my experience.
I disagree. I don't think a legitimate argument can be made for any performance gain being had from 20" wheels. Any gain in contact patch (which only really happens when you increase OD & Width together), will be negated by the weight gain and unsprung rotational mass cause by heavier wheels and heavier tires to boot. Acceleration will be hampered by heavier wheel/tire combo's just like the handling.
As for ride quality, bigger wheels ride better on smooth surfaces, but all of that goes out of the window on anything bumpy. Especially at speed. I have tracked 20's and street driven them.
The change is all about the bling. Big bling brakes need big bling wheels. Wheel well gaps filled with wheel, no space, and no big rubber. Looks a lot better, performance, not so much.
This is the same debate that's been going on since the 959 got "ridiculous" 17" wheels. Changing tire technology, heavier cars, etc move the bar...
Bigger wheels do ride better if you hold tire sidewall height constant. Which is what you need to do if you want to keep transient response time constant.
The standard GT3 brakes calipers are 380mm, the same as the Cup cars and they are running on 18" wheels. Recognizing that the caliper dimensions may be slightly different between the two, I would hope that a 19" wheel can be made to work on the GT3 for track wheels...
![](https://rennlist.com/forums/attachments/racing-and-drivers-education-forum/686475d1355018124-991-cup-video-m12_4775_fine.jpg)
Maybe the 991 Gt3's still will have to point by the olds relics due to the lack of available R compound and sicks!
CUP has 18" if its good for a CUP it's good for an identical GT3 with interior, it's what makes Gt3's so great..
Oh, wait... Crap.
Oh, wait... Crap.
I might argue that Porsche should work with Michelin/ Pirelli/ BFG to develop an R1 / A6 style dedicated track tire for the GT-3/ RS. I'm sure they think the market (mainly north america) is relatively small to justify this, but that would restore lots of track cred while offering a better package.
