991.2 GT3 Touring OEM Ride Height
Hi, anyone know the OEM specs for ride height? I think the previous owner lowered the car and want to take it to my tire shop and have them set it back to OEM and do an alignment.
socalcarguy (08-23-2024)
Okay, guess I will just take it to a porsche dealer. According to this tech here are the oem settings:
Okay, guess I will just take it to a porsche dealer. According to this tech here are the oem settings: https://www.instagram.com/reel/C7sIqOrJVHU/
Those tire pressures look high in the ride height video. I wonder if he puts the cold pressures up for ride height adjustment to adjust for warm tires.
@socalcarguy
I checked my 991.2 GT3 Touring before dropping (OEM height) and after lowering front
Front OEM: 67.5cm from floor to arch of the wheel (taken at the center of the wheel nut)
Front Lower: 66.5cm after 2 full turns of the nut so 1 full turn will lower or raise by 5mm about (estimated for first few turns)
I could measure from floor to bumper lip only after lowering and I am now at 10cm
Rear OEM: 68cm
See pictures below taken after lowering, I only took measurements (no pic before)
Rear OEM: 68cm
@socalcarguy
Rear OEM: 68cm
Rear OEM: 68cm
