991.1 GT3 RS PCM 4 with Apple Car Play= Done!
Well,
Bought my 991.1 GT3 RS, did some interior upgrades, then decided to that the car really lacked Apple Carplay.. Thought about the piggyback options, whole new head units, found on the 991 Forum some select few were doing acutal Porsche PCM upgrades.
I am a stickler for original, OEM like upgrades. I went down the deep rabit hole, will post all the folks you need to get ahold of, and things to buy, but for today, I post a picture of carplay in a 2016 GT3 RS with Factory PCM 4.0.
What a journey, very involved!
The following 5 users liked this post by Indyxc:
BLKMamba (05-13-2024),
FL4T-SIX (05-13-2024),
Jickel180 (05-13-2024),
robmypro (05-16-2024),
SterlingatBOM (05-13-2024)
Nicely done!
I purchased the Factory 3.1 PCM kit from NM Automotive. Comes with everything to put CarPlay and backup camera in my 991.1 3RS.
I just haven't had it installed yet.
What are the main differences with the 3.1 vs 4.0 PCM?
https://www.nmautomotive.co.uk
Nicely done!
The aftermarket alternatives are fine, but if you're a stickler for OEM level parts, and newer integration this is the way. I now have other screens like fuel economy, etc all on the PCM.
Does the track precision app still work with your new setup? I'd love to do this one day as the Joeyauto box just sitting on a rats nest of wires in my dash lives in my head rent free.
Definitely doing this. Car is going no where so I may as well make it feel more modern with the updated head unit.
Well if that looks that good and I'm taking the car apart anyway, may as well do this than update the 3.1.
Going to update to the 992 shifter
And add back up camera
plus add roll bar while the seats are out.
and may as well do the exhaust while the bumper is off.
can you list everything you had to buy and part numbers?
phoneyman (05-13-2024)
How did you get the gt3rs silhouette on startup? I purchased PCM4 from NMAuto with latest updates but he states the screen silhouette on startup states gt3rs but has a gt3 silhouette instead of respective gt3rs which he states comes like that from factory. Anyone know anything more about this or how to remedy a solution, thanks!
I’d love some more details on the install, were you able to fix the issue where the screen in the instrument cluster wouldn’t show the map? AFAIK this was the only thing the other walkthrough on Rennlist/YT wasn’t able to find a solution to.
Things you need:
1. PCM 4- You source your own.
2. Test Drive Scottland Sells the harness and does offer support on the process, I paid for his support (Well worth it),here is his youtube: https://www.youtube.com/channel/UCTA...9kgcGeV_w2PDeQ
3. You need a Porsche Piwis (To flash the gage cluster, and flash the PCM, both on updating the firmware, and configuring the settings). I bought mine of a member on Rennlist. While he helps you configure it, you need to be computer savy to install imagines he send you.
4. You need a car charger capable of least 30 amp that feeds power to the car during flashing.
5. You need an SD card, and ability to program the SD card to flash the PCM with latest updates (Again Test Drive Scottland, I paid for his support).
6. You need tools to disassemble the PCM / glove caprtment, felt electrical tape, and tools to ever so slightly modify the dash plastic behind the PCM as the PCM 4 is slightly longer and hits some ribs.
Those are the major things, a lot of small steps and butt puckering moments when you're flashing modules and they freeze in progress for 20 mins.
How did you get your gage cluster to work with the PCM 4, adn who made your harnss?
You do lose the map functionality in the cluster, as the cluster even with an update runs different maps. Apparently, you have to buy a new gage cluster from the .2 for full integration. Not worth it to me. That being said the native nav does work in the screen with direcitons and is MUCH better than PCM 3. You can also disabel that screen (The maps menu) so it doesn't show up, and is no longer a non functional option.
I purchased everything through NMAuto which should be shipping out soon but was unable to change the silhouette to an RS despite installing the latest updates he said. Is it possible to change the silhouette logo with PIWIS upon install? Thanks again!
Send me the link of what you bought. Is this what you bought?
https://www.nmautomotive.co.uk/produ...droid-auto-kit
If so, this is a piggy back system that runs on the PCM 3.1 (exsisting unit you have), not the same as a PCM 4 swap with original PCM 4.
