Brake fluid flush
#48
I could touch them, but not adequately reach them with a wrench. Also my nipples were really stuck and I have delicate wheels so didn't want to risk damaging them. I have 21 inch in the rear so I should have more space than your average GT3, but I still didn't think it was possible, but your mileage may vary.
#49
The problem with taking wheels off is you really need to use the breaks to tighten the center locks. How would that even work? If you can take off one tire at a time or one axle at a time, you’d be pressurizing the system each tire to put the tire back on. Its a lot of work. I’m sure it can be done.
#50
Much better to remove the wheels (it’s easy). You not only have Far better access, you avoid the possibility of dripping brake fluid on the wheels (will eat through paint quickly).
Get a friend to hold the steering wheel and brake pedal when doing front wheel r&r (rears can be done with parking brake alone).
Take off all wheels first and replace them when bleeding finished.
If you’re the kind of guy who wants to bleed your own brakes, you’re gonna want to do a bunch of other stuff that requires wheel removal (spark plugs, brake pads and rotors, etc). Worth learning now and do the bleed correctly.
#51
#52
I have taken the wheels off before. The problem is I have a 4 post lift that has a rolling scissor lift on it. I can only take an axle off ground one at a time. But you have a point, park brake should fix the issue of needing to pressurize the brake system to tighten center locks. I didnt think about this. And fronts can be tightened once all brake bleeding is complete and brake fluid reservoir is full.
https://jackpointjackstands/
Just skip the 4-post lift for a job
like this. Better to have all 4 wheels off while bleeding (can go around the car a couple times to ensure all bubbles out).
#53
Or get yourself a pair of these (for rear axle) and regular jack stands for front, since if you raise from rear side jacking point, it raises the whole side of the car:
GrantG (05-18-2024)
#54
Right tool for the job is crucial
What flare nut or box wrench do you guys use for the 11mm bleeder screws? PCCB.
This one I found : https://www.ecstuning.com/b-schwaben...SABEgLTXPD_BwE
I have box wrenches at home, just not sure if they will fit. Dont want to discover halfway
#55
Box wrench (6 flat) is best, regular flat. Put the wrench first, then bleeding hose. Don’t forget to torque it to 14Nm at the end before putting rubber cap.
#56
Never had to use a torque wrench for bleeder screws but its a Porsche so it will be a first. I have a high quality precision instruments 1/4” drive inch torque wrench. I’m assuming hand tighten with box wrench first and then 11mm socket is okay? Otherwise no way to torque them unless using something like a crow foot which wont fit there.
#57
peterp (05-30-2024)
#58
#59
I’m guessing you torque with the rubber protector open/removed position.
#60
3-Pedals (05-30-2024)
