Differential remove gt3 PDK box - gearbox and engine installed?
Hi
if the car is driven warm, the right drive shaft become some play (axial).
i removed the shaft and if you check the play of the stub shaft - there is a little but more than leftside.
i have to remove the differential and check the ball bearing! But there is no space to get to all of the screws!
how i can remove the diff. cover and the differential?
i cannot drop the engine because oil tank is in the way!
perhaps there is someone who knows whats to do?
Some play in the output shaft is normal. So, be mindful of that. Excessive play could be output shaft bearings, and things will start to leak before they fail (and you can rebuild the output shaft assembly).
thank you, i testet an other shaft and it seems that the play is about the same - so i change only the sealring
