991.1 GT3 coolant bleeding process
Forgive me if this has been covered elsewhere, but I couldn’t find it with the search.
After vacuum, filling my coolant system, what is the correct bleed process? I understand other 991 models require software to turn on/off a series of valves, but I also had heard the GT models don’t have this process and lack the valves.
So, for the 991.1 GT3, do I simply flip open the bleed valve and drive around a bit, then top off, or software needed?
Thanks.
Thanks.
