Which coolant for 991.2 GT3RS?
Is attached coolant OK to use to top off the coolant in my RS? Should I use 50% mix with distilled water?
This is the pink stuff that I also use in my 2022 Cayenne. Is this OK to use in 991 RS? I dont know what color of fluid is in there.
https://www.suncoastparts.com/product/00004330575.html
Or 1 Liter:
https://www.suncoastparts.com/product/00004330147.html
Yes, mix with 50% distilled water.
https://www.suncoastparts.com/catego...3RSENGMAI.html
This is the stuff you want (can't tell if it's same as what you have or not):
Or 1 Liter:
Or 1 Liter:
https://www.getporschesilverspringpa...nt-1-l-4330515
I think the one I got that ends with 515 is the replacement coolant to 147. I’m just not sure if you can mix these two coolants.
As per that link it says :
- SKU:000-043-305-15
- Description:Genuine Porsche Antifreeze/Coolant with silicon additive - 1 L. (previously 000-043-301-47)
It’s the pink stuff, it’s compatible w/ your RS:
https://www.pelicanparts.com/More_In...100#kitsComAnc
