Help with Paint Code: PTS Nardo Grey
Hi - can anyone help with the code for Nardo Grey PTS on a GT2RS? All i can find is code 998?
AFAIK the colors are the same from model to model. I've never heard of special paint codes per model. So one PTS code is the same throughout the model range.
hsb1001 (10-04-2023)
Where are you finding code 998? I'm wondering if you have found some umbrella Porsche code for 'Paint to Sample'. I know there is a catch all code for a non metallic Custom Color/PTS (98 or 9898__) and then another catch all code for a metallic Custom Color/PTS (99 or 9999__). There are finer details that go into this and it depends on which document you are looking at but you are looking for the (usually) 3 digit color code. You should be able to look inside the owner's manual and then in the first page or two of the 911 Maintenance book. There is a decal/sticker on the page with your actual color code.
hsb1001 (10-05-2023)
