Can this be Coded out ?
IIRC there is a PASM setting in the front or rear body control module, perhaps setting that to none would fix it. Otherwise can def go into the instrument cluster and disable the dash warning if that solution satisfies you
On my 2019 GT3RS I had to use the KW Suspension Delete Module. No issues for 3+ years now.
https://www.fcpeuro.com/products/por...Lw_wcB#fitment
Larry Cable (08-10-2023)
I'm runnig the ohlins suspension and I shouldn't have tried to code it out. It disabled a bunch of other stuff that rely on the accelerometers in the PASM computer (adaptive headlamps, active engine mount, variable power steering, etc.).
I now have the PASM delete kit and it's all great.
AdamSanta85 (08-09-2023)
You can code out PASM with PIWIS... there's a guy that did it and posted a youtube video here:
991.1 Coding out PASM with PIWIS 3 - YouTube
I think he's on this forum.
the result is that I had to get everything re-coded from the dealership because the car needs to be on their proprietary alignment rig to re-sync all systems with the windshield camera.
Save yourself the wasted $500 it cost me to learn all that.
You can just remove the notifications on the cluster not the actual system. People have done it on the steering notifications when changing to the gt3 calibrations
:/ I ordered the KW delete kit i wish this info was out there incase someone like me needed help. At least now it is if someone else needs it.
Same method if you replaced your factory seats with bucket seats. You should be able to get rid of the Airbag light in the instrument cluster.
