Max temps
Driving home, got stuck in traffic, only about 21 degrees Celsius, about 70 degrees farenheit in the UK and wet. Both oil & water temp went over 100 deg C (212 Farenheit).
Never seen it that high, is this normal or do I have an issue??
Normal, I have reached that temperature many times in traffic.
Very normal. Oil temps over 212 F burn off moisture and ok to 230 and maybe a little more. Water temps 195-215 F are fine.
