Engine lid won't open after Dundon Street headers fitted
Hi 991.2 gt3 experts!
Had Dundon Street Headers fitted, which are good so far, but now the engine lid won't open.
Did open when I collected, but no noise from the solenoid now. Fuse OK, as both brake lights work and is the same fuse for one side, I believe.
Am I right in that there is an emergency cable in one of the front fenders (I'm in the UK, so unsure what side for RHD car), that will open frunk and engine lid?? Need to remove fender liner to access.
Anyone confirm this and advise correct side to dismantle for a RHD car, if different>
Many thanks,
Mark
Many thanks,
Mark
Do you mean the mesh in the rear lid? If so, looking through, it appears to be above the carbon fibre shroud housing the fans, so can't see any cable to pull??
Any other suggestions?
Waiting for the garage to call back who fitted the system, but as they took 8 hours and chewed up 3 lambda sensors, not sure I have much faith.....
I took a couple pics. If you shine a light and looks closely through the mesh you will see a steel braided line that connects the latch to the actuator. You need to use a hook to pull it and it will open the latch.
these are the pics I could take
I unknowingly closed the engine lid which required the dealer to removed the bumper to re-attach. I did not witness the work so can't comment on procedure to access the cable with lid stuck closed.
TPG - thanks for the pics, but I think yours is a 3.8. 4.0 has the mesh higher up.
I took it back to the shop that did the install and they believe the switch has failed, so will order and install a new one.
The cable is hopefully in place, but there is no actuator noise, so hopefully the switch is the culprit
Did you sort this? I have same issue and already replaced the switch and checked fuse. I am going to shop tomorrow to manually open but need a full time solution. I assume the latch/actuator is bad or disconnected for some reason.
It was the connector under the rear motor cover for me. It was not fully seated, thus actuator wouldn't function. once I was able to pop it from underneath, plug in the connector correctly, no issues.
