Swaybar endlinks
Hi
there are a couple of options for endlinks, and while doing my research on them, I haven’t found many if any reviews.
some shops highly recommend them while others straight out said not to waste money on them.
Any one bought any or have experience with?
on a 991.1 GT3 mainly for track use.
Hi
They look very well-built. I previously ran the Tarett ones on my GT4. For a GT car that sees track time, I think front tie rods and end links are generally the first mods done. I just did my first event in the 991.2 GT3 on the OE alignment (with OE parts) just to get a baseline this past weekend, and while it was a ton of fun, I'm definitely excited to put all the aftermarket alignment bits on and get it properly set up. I'm sure others will respond with their first-hand experience, but pretty quick research on RL will support doing end links and front tie rods, followed by an alignment and corner balance.
I hope this helps!
I've just been using complete factory swaybars without issue. Aftermarket adjustable ones can tend to be noisier and wear out sooner, but they have the advantage of being able to zero out the preload on the bars after a corner-balance if you are very focused on track behavior (above all else). Preload can alter the corner balance numbers, once the bars are reconnected (if disconnected during corner-balance) and can have a small effect on the handling of the car around the center steering position.
Anu2g (03-27-2023)
