I’m looking at possibly installing a 4 post lift but was wondering can you easily jack the car up using a basic bottle jack placed on one of the sliding jack trays? I wasn’t sure if there is enough clearance to get the bottle jack in there and jack the car up?
Or is it necessary to purchase one of those sliding bridge jacks? (I would prefer to not have to use one of these)
I have 2 of the sliding bridge jacks on mine - so obviously that is what I use.
I don't think that would work, as the lift points are where the tracks are - so with the sliding bridge jacks the arms extend out between the car and the track -to adjust to the lift point and then you jack up the car once positioned on either side of the car.
The sliding tray is on the inside of the tracks - so you couldn't get a bottle jack under the lift points (as they are under the car and just above the tracks..
If you use something other than the lift points on the car - you could but would need to be something on the frame of the car.
PS. The 4 post and bridge jack from my auto DYI perspective - is the best investment I have ever made. So if you have a 4 post, get the bridge jack. The damn jack is nearly as expensive as the lift, but well worth it...
Here is a pic of my touring on the lift - You can visualize the lift point is just behind the front tire and in front of the rear - the jack point would be about 1/2 way of the width of the track, so thus when you use the bridge jack, the lift arms move in and out to position them where the lift points are.
I can take a pic with it up and jack positioned if you desire.
It might but could be to high to get under the car.
Of course for the price, you are within a few hundred of just getting a bridge lift for the 4 post. Also I prefer when using a 4 post (unless absolutely needed) - for tire and other, I like only one axle being off the track at one time. It might be ok to do, but I am extra cautious and would not be with quick jacks on the tracks and both sides of the car up in the air, I would be nervous.
Which model lift and which bridge jack do you have? Any issues with bridge jack arms lining up with the factory jack points or clearance issues getting the arms under the car?
I was going to get a 4 post with sliding jacks but Bendpak said a 996TT engine + gearbox couldn't be dropped between the rails. So I went 4 post for stacked storage and separate 2 post asymmetrical for wrenching. Both rock. DIY'd the install of both with a buddy. No one died.
I have an Atlas Apex 8 lift and standard Atlas RJ-35 bridge jack ($1800 extra). No issue at all for my Porsches, McLaren, or other cars lining it up to the jack points. Really quick and easy,,,
I choose atlas as that is what a local dealer sells, and I did not want to set it up myself, as would be a pain in the neck, and not many other dealers in my area. But it is sturdy and works great, have had it 4 years or so, no issues - outside of normal maintenance.
